Discuss Wiha in a Wera ?? in the Electrical Tools and Products area at ElectriciansForums.net
Moley
Supporter
Do the Wiha interchangeable VDE blades fit the Wera handles? The Wiha seem to be easier to get hold of than the Wera ones. I'm after the slim bits, the ones where the insulation is the same diameter as the tip, to go with my new set.
Bugger! Oh well, good job I asked before I bought. I suppose I could buy a Wiha handle too.
plenty on ebay. i have to replace a lost wiha bit every month or so. only problem with the wiha is that the bits fall out when using. usually off a ladder or into a bottomless cavity.
Amazon often have Wera slim blades at good prices, although they can also be quite expensive at times.
i didn't know wera did slims. the wiha ones are about £6 odd on ebay.
On the topic of Wera screwdrIves. How you getting on with the Wera interchange Tel , hope it’s serving you well...
fin mate. only comes out when there;s no wet-pants in sight thieving barstewards.
Reply to Wiha in a Wera ?? in the Electrical Tools and Products area at ElectriciansForums.net
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
This is the last thing I have for sale if anyone wants a new screwdriver set Wera quick change handle Torx 15,20,25 Slotted 4mm, 3.5mm (and a...
Does anyone use the Wera KK Vde interchange screwdriver ( the handle and removable blades(tips) type ) I have a Spare handle and a 3mm flat , ph2...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
I was wondering what is the cheapest option to get a (legitimate) copy of the EN standards, such as IEC/EN 62305 on lightening protection? I...
