Just want to check my sanity;
I've got an emergeny light to add to my setup board (Test facility and light fitting itself)
I've a 2G MK Grid system - 1 SP 2-way swtich module (aka normal light switch) and a SP fishkey module (to siwtch the supply to the fitting and allow it to run on battery alone as is intended for them - I understand that 2P Fishkey switches switch both N & L and are similar in reverse appearance as a SFCU (Supply & Load marked)
My understanding (as i cant find pictorial instructions for love nor money) Is that the test switch is installed between the perm live tail (in this case the the COM terminal of the neighbouring SP 1-way swtich) and the EM fitting itself.
What i hadn't realised is that EM keyswitches come in SP and DP varieties and should probably go for a DP version instead.
2 Way module has 4 terminals (COM, 1, 2, SP - Only COM, 1 and 2 have screws)
Fishkey swtich has 4 terminals (COM, 1, 2, SP - Only COM, 1 and 2 have screws)
Current setup:
(Ceiling rose terminals numbered from L-R ( L (1,2) Loop (3,4,5) N (6,7) )
perm live from CU to ceiling rose (Loop terminal 3)
neutral from CU to ceiling rose (Netural terminal 1),
P/L CR (Loop terminal 2) to COM of Fishkey
Strapper from Fishkey COM to to 2-way Light switch com
Neutral (2-way temrinal marked 1) back to CR Neutral terminal 2) (Switched live) (I'm aware I have this in the wrong terminal- SL would go to terminal 1 in the rose
Power would leave the rose from terminals 5 and 7 (only unused terminals at the rose (due to Rose being end-of-line) and go on to EM light itself
Have I got this right?
Ceiling Rose
2way switch & EM test rear
2way switch & EM front
Current setup:
Ceiling Rose
2way switch & EM front- TL;DR
- EM Fishkey switch & 1way switch - sanity check on wiring
