C
cadspark
Currently rewiring 1970's bungalow with no phone point. Cable from overhead post comes to the bungalow but nothing connected inside and no master socket. It is a buy to let so customer doesn't want to connect phone but wants a point in the stud work wired ready. Can I put my own master socket on wired up ready and leave cable coiled in loft ready for BT to connect to. If so do they have any specific requirements for type of phone cable?
yes you can put your own master point, i'd be surprised if BT man would go in attic and drill to outside etc, maybe you could drill and get the cable to somewhere close to the existing cable off the pole and then BT can just connect it in. As for cable I think standard 3 pair Telephone cable would be ok, although you will only need to use 2 cores. I usually double up a couple of cores both ends just to get a better signal
you can prewire your 6 core to (future main socket )poke out by the fixing bracket leave it coiled,when needed bt will terminate to it to inline joint and fit NTE5.
