C
Clocks
Hello, does an electric patio heater (1.5/2kw) need special wiring/ it’s own circuit etc? Will a two core grey cable with earth be ok?
Must be a large Patio Heater TTC, to melt the ice caps, seriously though you are correct, just couldn't resist the chance to make a funny.Patio heaters are the devils work.
No wonder the ice caps are melting. What a waste of energy.![]()
Any idea which Reg that is Tel? cuz I am arguing with a friend of mine and quite honestly I can't find a reference, other than a recommendation.we don't know your level of competence, so hard to advise. all i can sayis that regs. state " a load of > 2kW should be on it'sown dedicated circuit." a 2.2kW hot tub comes fitted with a 13A BS1363 plug. if that's any guidance.
Cheers TTC will take a lookIt’s not a reg. It’s guidance. Appendix 15 IIRC in the good book.
SOZ. PETE. As post 7. guidance.Any idea which Reg that is Tel? cuz I am arguing with a friend of mine and quite honestly I can't find a reference, other than a recommendation.
So OK Tel thanksSOZ. PETE. As post 7. guidance.
