This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Today I have wired up 2 new zone valves and a 2nd thermostat to my heating system.
The existing system is a gravity fed boiler with no valves. It has a separate programmer and thermostat.
There is a 3 core and earth running from the programmer/thermostat to the boiler. I have broken into this to connect the new valves and 2nd thermostat.
28 wires later everything is working, except using the new 2nd thermostat the pump runs but the boiler doesn't come one.
To run central heating, do two wires need to be Live to the boiler? As in, there are separate pump and boiler feeds?
Thanks.
Depends on the boiler. Check the manual or with the manufacturer. Typically not if a combi boiler or if the pump is integral to the boiler.
Thinking about it, the programmer and existing thermostat both send a Live feed to the boiler, when the programmer is on it heats the hot water which doesn't need the pump. Then when the stat is turned on the CH pump comes on as well. So two Lives are needed for the CH.
Thanks.
guesseing due to lack of info,, you say it was gravity fed before, therefore it doesnt need pump overrun. so the boiler should fire regardless of what the pumps doing.it only needs to have a feed sent from the valve to fire. the motorised valve that you seem to say opens and makes the pump run,, take that live to the boiler... without more info, its like total guess work,, but fun to think about!!!!
If hot water is gravity fed,with no valve,you can not have any of the two heating zones on without having the hot water on due to pipe work configuration therefore it is pointless having a live to the boiler from the heating valves as even if hot water off at programmer ,it will still be heated
Therefore live to the boiler is run from hot water channel and each heating zone valve is operated by heating channel(s) through respective wall thermostat's,then each zone valve once opened will send power to the system pump to allow circulation round heating system
