G
garymcgee
Hi everyone.
to give you a picture of the installation my question relates to i will describe from the source to the furthest away point.
Starting off at a main isolator a 3 core & neutral wire armour cable runs for about 30mtrs and supplies a 3-phase distribution board. From this 3-phase distribution board there are 4 sub-mains cables that are ran to 4 separate appartments. (1 cable to each). Each appartment is small in size and for this question have two ring circuits for socket outlets.
Appartment 1 fed from L1 at 3-phase DB.
Appartment 2 fed from L2 at 3-phase DB.
Appartment 3 fed from L3 at 3-phase DB and Appartment 4 is fed from again from L1 at 3-phase DB. That 3-phase DB does also supply a few other low powered circuits but nothing else appart from Appartment 1 and 4 are supplied from L1. Hope thats clear enough. lol.
Anyway, my question. I carried out an Earth loop test on a socket in the furthest away appartment, appartment 4, supplied from L1. All the correct wiring indicator lamps on the Robin test Equipment indicated the wiring was correct, so i proceeded and test result was ok.
I carried out the same test on Appartment no 1, fed from the same phase and again the same result.
When i attempted to carry out the same test on the other 2 appartments ie 2 and 3, which are fed from phases L2 and L3 the RED Wiring Incorrect indicator light came on. P-E and P-N green indicator lamps were on indicating that was ok though.
Within the appartments all wiring is correct. The Robin test equipment is for single phase use only so it wouldn't detect a cross phase at source would it?????
Having not further investigated at this time im thinking the problem is from source to the 3-phase DB.
Any other suggestions guys.
Thanks.
Gary.
Thanks.
Gary.
