K
kung
Hey anyone watch these programs on tv ? just browsed through the website and on the electrical section its got how to do this and that etc on lighting its got advice and video but no mention on borrowed Neutrals or if you have a lighting circuit with no cpc etc ! other how to bits are good eg plastering etc on the whole its not a bad site !
Just watched the video about replacing the pendant, seems a bit pointless really as they only show a scenario with 1 cable at the fitting which is a rare occurrence to say the least. How many people will see him putting the black in the neutral terminal and the red in the live then just assume they do the same with all three cables when they're met with a fed rose! I'd also have liked to see him doubling over his wires as it looked like 1mm seeing as we all know how easy it is to over tighten a terminal and crush the wire. Also, what the hell was he banging on about with wires touching?! If the supply is isolated the worst that will happen (and this is only if it's on a 17th Ed. CU) is you'll trip a RCD. I'd have also preferred to see him take the fixed installation wiring behind the flex as it makes changing/shortening pendent drops much easier and a short lesson on safe isolation with the use of a approved test meter would be helpful rather then just throwing the switch a couple of times.
