Discuss You can't polish a xxxx in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Sitting here doing an estimate.
Flat in not so nice area, and this is the spec for the average sized living room:
6 x downlights
6 x wall lights
4 x low level recessed lights
1 x 3G switch inc 1 x dimmer
I suspect this is being done up as a rental so I would suggest:
1 x pendent
1 x on/off switch!
How daft....
I know Murdoch. It really does get on my nerves when landlords try and make properties pleasant to look at and live in.
Next thing will be to paint it something other than magnolia!!! fools. :)
......nowt wrong with magnoliao_O
Reply to You can't polish a xxxx in the UK Electrical Forum area at ElectriciansForums.net
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I have an old emergency light with an almost dead 6 volt 4 amp battery inside, so I switched it to 2 x 18650 (3.7v, 4800mah) = 7.4 volt 4800mah...
Been to a fault finding job and lights where tripping the rcbo. After further investigation we found that it was a blue strapper cable (old...
I am in a bit of a pinch at the moment and trying to argue a massive amount of used of electricity with my provider which I find it hard to...
