G
Garry Thompson
Am I right in saying it's still a no no to run this valve solely on it's own to the programmerThe new zone valve needs to T off before the existing one
Are right yeah sorry the underfloor heating is branched off before the valve
Thanks for the help guys it's most appreciatedWhereabouts?
That new programmer will work but needs to be wired to the control centre to operate the boiler via the new zone valve.
Just take 5 core flexes from the wiring centre to all pieces of kit
Sorry in regards to ur whereabouts the valve is in the back bedroom just after where the ufh pipes run out into the new build extension and down to the pump on one of the image'sWhereabouts?
Well it's taken off the flow and return before the manifolds for the rads yesSo the flow and return for the ufh is taken off the rads?
Did do that straight away but as I'm sure your aware of on site circumstances around other gobby trades it's nice if u can find out the right way from the right people if possible and get a job done if not admit defeat for safety/the right reasonsHold your hands up and say it’s too much.
The customer should have asked your gaffer before he went on holiday
It's the way the punter wants it done and using the old chestnut that he used to be in the trade and knows how things should work lolI know all too well other gobby trades.
Is this part of the work you’re doing, or a temporary supply to keep the UFH on while the works are being done?
