Discuss Zone question in the UK Electrical Forum area at ElectriciansForums.net
Hi,
im just wondering what others thoughts are on this.
im fitting some outside lights tomorrow for someone, one either side of their patio door.
im going to drill straight through and then take the cable up the dry lining on the inside to the top near the ceiling, take it across the top and the down into the switch.
the wire on one side of the door will not be in a zone as the wall is greater than 100mm. The other side is ok as falls in line with the switch.
Personally I can't see any problem with it as there isn't really an alternative short of creating a zone some how.
its a brand new house by the way, RCDs etc.
Cover with a 3mm steel plate? Unless I'm missing something in your description this is your only option unless you 'create' a zone with a switch, as suggested by Murdoch?
Reply to Zone question in the UK Electrical Forum area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
Rewiring an old farm cottage… every wall brick and previous wiring not done well at all. I can’t locate any of the prescribed zones diagrams on...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
