bought mine on ebay 'fully insulated' apparently............
As below plus full set of xrp, laser level set on tripod, drill bits loads of etc.
dont tell the other half how much that lot came too :D
I see you have the same (specalist obviously) wander lead as I have. I used bell wire though and my reel is 60m not 75m, as luck would have it the resistance of the my real is exactly 2.0 ohms so easy work out in case I forget to zero it on the meter.
:D $4.99 from morrisons couple of bits from rs bit of spare cpc. all in for a lot less than the kewtech one i nearly bought from the wholesalers, everyones a winner:)
