So are you going to run in the supply using 2.5mm or 4mm cable?
…….Might see if i can get some 3.5mm.
But seriously its a bit of a run so it's going to be 4mm SWA.
I still can't get over their 25A mcb business, Are they commonly stocked?
Will 4mm be big enough if it is a bit of a run?
What is there to get over? Most decent manufacturers offer a 25A mcb
Yea i checked out 'tlc' and a couple of other online shops which only displayed the 'standard' rated mcbs. I can't think I've ever come across a 25A mcb. Perhaps it's the 'go to' mcb for air con units!
That depends on the size of AC units, I have been wiring quite a few up recently that are rated at 12 amps.
yea 4mm is plenty, thats why i say its a bit of a run and not a hell of a run. I will be checking appendix F though.
yea 25A mcb makes total sense now, thanks
Just stick a 32A one in if the load and cable are OK.
Just saying!
Here's a 40A isolator i fitted today when I put a 32A circuit in for the hot tub.
