Deleted member 72666
Yes way, dude!!!No way!!!!!!!!
yea 4mm is plenty, thats why i say its a bit of a run and not a hell of a run. I will be checking appendix F though.
yea 25A mcb makes total sense now, thanks
Ok sorry dave, My basic question was just about what's an acceptable protective device associated with a 25A rotary isolator. As i'm used to 16A, 20A or 32A.
Here's a 40A isolator i fitted today when I put a 32A circuit in for the hot tub.
Surely that's not SY cable installed outdoors?
Yes... What's your point?
I accept that. I've got another next week, I'll put some black flex on it.
flexishield or NYY-J cable could be used.
I have installed dozens if not more than dozens of air con supplies and it is usually a 32 amp Isolator fed by a 6mm2 supply, obviously the cable size will be determined by the length of run, pretty standard 32 amp and 6mm2.When an air con installer asked for a 25A isolator are they expecting a 20A or 32A supply to it?
Client request, and why not 6mm2?why 6mm and not 4mm?
