S
SPARK2B
[FONT=&amp]Hi all, could anyone put some info my way, i was trying to jot all this down in note form whilst doing other things at college, this is the testing for the 204 exam i ahve to do nex week, can you guys go through and suggest any adjustments / errors i have made, i have left one of my notes from last night at college and cannot get it until tuesday, it concerned checking polarity "at this stage" and was in with the continuity of cpc part of the tests, beeen awake for 30 hours now and am really letting this testing get to me as we have done next to none at college, and now i have yo do it next week to pass the exam, and i want to just blitz it and get it done, hence the studying...as always any and all help, much appreciated!!!
it wouldant be a problem but im alone in it, as the rest of thee class (bar one other guy) are not going to be doing it for 5 weeks, after half term, purely because mine and my mates scheduals allow us to go in to college in the daytime, and not just eves,....thrown in at deep end....so we want to blitz it!
[/FONT][FONT=&amp]
Continuity of Cpc and bonding conductors[/FONT]
[FONT=&amp]1. [/FONT][FONT=&amp]The line conductor is connected to the Cpc of the same circuit at the consumer unit [/FONT]
[FONT=&amp]2. [/FONT][FONT=&amp]measurement taken at ALL accessories on that circuit between line and Cpc[/FONT]
[FONT=&amp]3. [/FONT][FONT=&amp] The highest measurement obtained is recorded on the test report. Test result is[/FONT]
[FONT=&amp] R1 + R2. [/FONT]
[FONT=&amp]4. [/FONT][FONT=&amp]The line conductor and neutral conductor are then connected and the above repeated to obtain R1 + Rn[/FONT]
[FONT=&amp]Continuity of ring circuit[/FONT]
[FONT=&amp]1. [/FONT][FONT=&amp]End to end tests for Line (r1) Neutral ([/FONT][FONT=&amp]r[/FONT][FONT=&amp]n) Cpc (r2) [/FONT]
[FONT=&amp]2. [/FONT][FONT=&amp]Calculate predicted R1+R2 by r1+r2/4, record predicted R1+R2 in notes[/FONT]
[FONT=&amp]3. [/FONT][FONT=&amp]Create a temporary link in CU between Cpc +Line [/FONT]
[FONT=&amp]4. [/FONT][FONT=&amp]@ each socket on the ring, either with plug adaptor or direct connection @ terminals measurebetween line and Cpc , this is the R1+R2 , make a note of each value in notes[/FONT]
[FONT=&amp]5. [/FONT][FONT=&amp]In column R1+R2 record the highest value[/FONT]
[FONT=&amp]6. [/FONT][FONT=&amp]Disconnect temporary link[/FONT]
[FONT=&amp]Insulation resistance [/FONT]
[FONT=&amp]1. [/FONT][FONT=&amp]Remove all lamps and sensitive equipment from the circuit to be testes[/FONT]
[FONT=&amp]2. [/FONT][FONT=&amp]Move all breakers to the ON position[/FONT]
[FONT=&amp]3. [/FONT][FONT=&amp]Place a temporary link between bus bar and neutral terminal[/FONT]
[FONT=&amp]4. [/FONT][FONT=&amp]Test @ 500V between Earth terminal and Neutral (this test L+N down to earth)[/FONT]
[FONT=&amp]5. [/FONT][FONT=&amp]Remove link[/FONT]
[FONT=&amp]6. [/FONT][FONT=&amp]Test between L+N @500V[/FONT]
[FONT=&amp]7. [/FONT][FONT=&amp]2 way switches must be operated at each stage (test, operate switch, test)[/FONT]
[FONT=&amp]Bonding continuity[/FONT]
[FONT=&amp]Disconnect bonding from MET, and on Ω setting take measurements between both ends, record results in notes.[/FONT]
THANKYOUUUUUU!!!
SPARK2B
[/FONT][FONT=&amp]
THANKYOUUUUUU!!!
SPARK2B
https://www.youtube.com/watch?v=yY8nsGn2xBohttps: //www.youtube.com/watch?v=zSATFrqlSpghttps: //www.youtube.com/watch?v=p6j4JeRU3Z0 sorry if the three vids didn't come out but if not go to you tube, there are a great selection of testing vids
Calm, calm, calm, take it easy, it is not the end of the world.
Deep breaths in and out.
Chill.
Right now we can proceed!
Being awake for 30 hours will not help, you need to be able to concentrate and be refreshed.
1. The line conductor is connected to the Cpc of the same circuit at the consumer unit
2. measurement taken at ALL accessories on that circuit between line and Cpc
3. The highest measurement obtained is recorded on the test report. Test result is
R1 + R2.
4. The line conductor and neutral conductor are then connected and the above repeated to obtain R1 + Rn
This is not part of the testing
Bonding continuity comes with the above
Isolate the supply
Disconnect bonding conductor from MET, and on low Ω setting measure the resistance from the disconnected end to the extraneous metalwork(this tests the bonding clamp connection), record results in notes.
1. End to end tests for Line (r1) Neutral (rn) Cpc (r2)
2. Calculate predicted R1+R2 by (r1+r2)/4, record predicted R1+R2 in notes
3. calculate predicted R1+Rn by (r1+rn)/4, record in notes
4. Create a temporary link in CU between the opposing Cpc +Line forboth legs of the ring (crossover, figure 8)
5. @ each socket on the ring, either with plug adaptor or direct connection @ terminals measure Ω between line and Cpc , this is the R1+R2 , make a note of each value in notes. Values at each point should equal predicted value (within 0.05Ω)
6. In column R1+R2 record the highest value
7. Disconnect temporary link
8. Create a temporary link in CU between the opposing Neutral +Line for both legs of the ring (crossover, figure 8)
9. @ each socket on the ring, either with plug adaptor or direct connection @ terminals measure Ω between line and Neutral, this is the R1+Rn , make a note of each value in notes. Values at each point should equal predicted value (within 0.05Ω)
10. Disconnect temporary link
1. Remove all lamps and sensitive equipment from the circuit to be tested (linking the incoming and outgoing cables to bypass items such as dimmer switches)
The following is one type of acceptable test: L+N to E
2. Move all breakers to the ON position, main switch OFF
3. Place a temporary link between bus bar and neutral terminal
4. Test @ 500V between Earth terminal and Neutral (this test L+N down to earth)
5. Record the value
6. Remove link
The following is the other type of acceptable test: test from each conductor to every other conductor of a disconnected circuit
1. Test between L+N @500V (operate two way switches) Record the value in live-live
2. Test between L+E @500V (operate two way switches) Record the highest of this and the next value in Live-earth
3. Test between E+N @500V
Record the highest of this and the previous value in Live-earth
You can do either test (or both if you wish) but do not get them mixed together.
Polarity is confirmed by performing the R1+R2 testing as described above
Functionality is confirmed on dead testing by physical movement of switches/ circuit breakers and continuity testing across the switch.
If the circuit is live then functionality is tested by switching on each control and confirming expected operation.
Chill.
R1 + R2.
Isolate the supply
5. Record the value
6. Remove link
MAAANNNNNNN!!!.....I WAS WAY OFF!!
many thanks for this imput mate!!
time to digest!!....iv slept now,....things make a little more sense!!
THANKOOOOOOOO
SPARK2B
Chill.
R1 + R2.
Isolate the supply
5. Record the value
6. Remove link
I have been through and made the changes and i think have them all in place, iv checked and double chekcked, but still may have missed a bit or got it in the wrong place, iv read it over a few times,...but would like anyone qho can help to just check over it for me
really appreciate it guys!!
HERES MY CORRECTIONS....
[FONT=&amp]Continuity of Cpc and bonding conductors[/FONT][FONT=&amp]
R1 + R2.
4. The line conductor and neutral conductor are then connected and the above repeated to obtain R1 + Rn This is not part of the testing
Isolate the supply
Disconnect bonding conductor from MET, and on low Ω setting measure the resistance from the disconnected end to the extraneous metalwork (this tests the bonding clamp connection), record results in notes.
2. calculate predicted R1+Rn by (r1+rn)/4, record in notes
3. Create a temporary link in CU between the opposing Neutral +Line for both legs of the ring (crossover, figure 8)
[/FONT]
[FONT=&amp]4. @ each socket on the ring, either with plug adaptor or direct connection @ terminals measure Ω between line and Neutral, this is the R1+Rn, make a note of each value in notes. Values at each point should equal predicted value (within 0.05Ω)[/FONT]
[FONT=&amp]5. In column R1+R2 record the highest value
6. Disconnect temporary link[/FONT]
[FONT=&amp]
Record the value
5. Remove link
6. 2 way switches must be operated at each stage (test, operate switch, test)
[/FONT]
thanks again
SPARK2B
I have combined CPC and bonding conductor continuity sections and put back in to the ring testing the line to cpc crossover testing (you need to do both L/N and L/E)
Test result is R1 + R2.
Isolate the supply
Calculate predicted R1+Rn by (r1+rn)/4, record in notes
Create a temporary link in CU between the opposing cpc +Line for both legs of the ring (crossover, figure 8)
Test @ 500V between Earth terminal and Neutral (this tests L+N down to earth)
Record the value
Remove link
Gents, will it help or hinder the thread if I edited your posts (& reply with quotes) to show the correct number sequence? Plenty of time to reply, I'm off for a shower. Looks like I've been down the pit all day. ps Great posts by everyone :smile:
It might make my response(s) easier to understand to someone reading it from new, then you could delete the two explanation posts (6&7).
Reactions: 2 people
did i do summin wrong.....just got a load of messages from dan saying posts deleted etc
fluancy.....number sequences ??...
i dont know?
thanks to all so far for help!!
SPARK2B
i dont know?
SPARK2B
LOL that was me editing the sequence of tests that Richard posted up. One of the sequences was wrong as he posted up (now deleted). Richard Burns wants to keep the testing sequence correct for you and any others that read this post over the years.
You've done nothing wrong mate, just bin the e-mails. Richard and I are cleaning up this thread for everyone to gain from. Good thread by the way, I like it.
iv told you guys.....you dont know how much this is helping me....been stressing
you guys rock
SPARK2B
Reactions: 2 people
you guys rock
SPARK2B
All the Mentors have the same frame of mind. We all help the ones that put effort into themselves. Asking questions and getting help like the above is a great way of doing it.
@ Richard. Are you happy with the new edited thread and the reply with quotes? Looks good to me.
Sorted, thank you for the effort to get things right
print away, I will not need to change anything else!
Number sequence now makes sense and post is clearer to follow.
oohhhh i cant get the page with the finished article up to print.....could some helpful soul link me...im guessin my fones goin nutts,.....again!!
SPARK2B
My original response is post 3, the final correction of your second list is post 7
SPARK2B
With your permission "ONLY" I can e-mail it to you if you like? It is a Golden rule of the Staff, need your permission first.
I hope I'm not crashing the party here, otherwise I can delete this.
On the IR test, the advice is remove stuff that could be damaged by the 500V. Lamps,dimmers and indicators.
How does this work in practice, does it mean you have unscrew the wires at sockets and swtiches etc , terminate in connector blocks or wago connectors.
Is the 250V test guaranteed not to damage anything ?
Generally all equipment must be able to withstand the 250V test as it is subjected to a peak voltage of 325V from the a.c. waveform in normal operation.
If something breaks from the 250V test then it was already faulty.
Testing at 500V subjects the equipment to a greater voltage than normally experienced and so can provide an early warning. If there is a voltage leak at 500V then there may be no (significant) voltage leak at 250V but the breakdown may soon come.
On a practical basis for exam testing then for a dimmer switch you would remove the cables from the terminals and join them together to bypass the dimmer but still allow testing past the dimmer, fluorescent lamps would be removed and ballasts disconnected, if the light is at the end of the line then there is no need to reconnect the cables, however in a practical sense you need to be sure no one can access the cables whilst you are testing so they do not get an uncomfortable shock. Items with neon lights would also need to be bypassed.
For exams a terminal block or wago are normally provided for this purpose.
If you are permitted to do the line and neutral connected together to earth IR testing then sensitive items should not need to be removed, although if you are unsure about something then removal is always possible.
(A non standard approach is to test at 250V first and see if there is a low reading, this may indicate something that may be damaged by 500V so find that and disconnect it before testing again at 250V and if OK then at 500V. This is not something that is usually covered for exam purposes.)
ALL SORTED NOW THANKS PAUL.M!!
i really appreciate all your help on this testing mumbo jumbo!!
thankyouuuu!!!!
SPARK2B
ANNNNND JUST TO CLEAR UP A POINT, ADMIN / STAFF....can email me at any point on any matter, to clear up anything, supply info, ask , inform, etc etc, from now , in perpetuity,.....i get nothing but help from this forum / staff, and so give permission by the all mighty flying spaghetti monster for this to be the case
(really!)
thanks again
SPARK2B
HELP please, - testing for 204 exam
Electrical Course Trainees Only
SPARK2B,
SPARK2B,
