Only thing I can think of is that it is in the manufacturers instructions.
Maybe so. Strange if they do actually specify this though. Daz
Some of the Gas Boiler manufacturers instructions say to use a plugtop...
DazMaybe so. Strange if they do actually specify this though. Daz
Note: Mains supply to the boiler must be
through a fused double pole isolator
situated adjacent to the appliance. The
isolator must have a contact separation
of 3 mm minimum in all poles.
(taken from: INSTRUCTION MANUAL INSTALLATION, COMMISSIONING & SERVICING WALL HUNG RSF GAS-FIRED CONDENSING COMBINATION BOILER GREENSTAR CDi FOR SEALED CENTRAL HEATING SYSTEMS AND MAINS FED DOMESTIC HOT WATER)
[h=3]greenstar-cdi-installation-manual - Abacus Flame[/h]
How many power cuts does he have normally?
If Grid power cuts are a common problem you could install a duel supply Isolation switches set up at the CU. Wont look very pretty in a domestic home but it is suitable for his needs/concerns. Locking off is essential and an instructions list will have to be placed near the Iso set up but it is do-able and can feed the house (obviously only for restricted circuits... lights, small socket circuit and his boiler).
Only done this once in a remote country side house but it works great. All depends on the home owners ability to understand the importance of locking off Generation supply whilst under Grid supply etc etc etc. Also change the generator plug to a 16A commando![]()
A 13A plug is both fused and double pole.
