I use a corded Clarke one from machine mart. Does the job and was about £45. There are a few other brands at that price too.
Battery units of any brand will be a lot more expensive, apart from the aldi ones.
I bought a £20 one from Aldi in a case the other week , I could not resist it.
I used it a few times and must say it is mint. 300w and variable speed it's a bargain.
The only thing is the blade base , it has prongs and is tightened down by an Allan key boss and has come loose , but prob because I was frightened I had over tightened it.
It is cheap enough to leave in the vehicle and have to hand for those unexpected uses.
Thanks for the much appreciated input guys! Just an update. They are big slabs of oak, so not to bad to drill through. Although i did stock up on some spade bits! I decided to use a spade bit for around the edges and then used a reciprocating saw to cut through the rest. It took about half an hour to cut the opening so not too bad. Although very intensive on the batteries!
Cheers again!
As a few others have said 100% use a router. Would take a chippy no time at all to do once a ply jig is made. You would end up getting vibration white finger (or whatever it's called) if you did a load with a multi cutter.
Routers are easy enough to use, you could hire one.
I haven't got a router , how deep a cut can you get with them.
Not sure on that. I have cutters that can go approx 50-60mm deep. If the cutter was not inserted fully could probably go to 75mm. I usually use it for kitchen worktops, so rarely go past 40mm. They take a lil while to set up but are a good bit of kit to have.
Thanks for that. It's mainly kitchens I've seen them used on.
I often fancied getting one .
I do 70% elecs and 30% joinery. Never found much for use it for electrical work tbh. I did route out a channel for a telephone cable once but that's the only time I can recall. There's quite an art in getting a decent masons mitre on worktops. It's also good for letter plate holes in front doors.
Yes , I thought about the uses, I'm not great with woodwork, and my cuts are mainly access,so i haven't bothered.
i got the aldi 10.8V and the 240V. both good bits of kit, but the cordless, i burnt the speed control out. just bridged it out so it goes full speed all the time.
To be honest I was surprised, I have a Dewalt 350w too, but I don't leave it in the vehicle. With the exception of the blade fitting the Aldi one does the job just as good, and I leave it in the vehicle overnight for those days you don't think you will need one.
PS ,based on your recommendation I will get a cordless the next time they have them in.
I bought the headlamp you recommended .
Davisss,
ruston,
