B
Blademan_98
So any earthed conductor is called a neutral?
Not exactly, just in the context of your original question.
The neutral is connected to earth at the transformer.
Does BS7671 define neutral?
it defines neutral conductor.
Somewhere in the first few pages you'll find a section called definitionsWhat is the number of the section?
part 2 definitions, page 32 BYB
Neutral Conductor. The conductor connected to the neu-
tral point of a system that is intended to carry current under
normal conditions.
Neutral Point. The common point on a wye-connection in a
polyphase system or midpoint on a single-phase, 3-wire sys-
tem, or midpoint of a single-phase portion of a 3-phase delta
system, or a midpoint of a 3-wire, direct-current system.
Informational Note: At the neutral point of the system, the
vectorial sum of the nominal voltages from all other phases
within the system that utilize the neutral, with respect to the
neutral point, is zero potential.
Gentlemen,
If i may , this is what the '14 NEC has>
~S~
So under NEC terminology, neutral is defined as a conductor which only has a phase cancellation relationship with two or more actives?
That's a question for an NEC forum really, we don't deal in those matters here.
It has a potential difference to what is called live. Otherwise you wouldn't have any transfer of energy from source to load.This thread has veered off course and no longer neutral lol
As others have said, in context, it is defined as neutral by the regs. It has no potential and therefore neutral.
