P
Piratepete
Met a (proper so he said) electrician in my local Denmans. In a discussion about changing a CU he said I needed to put new tails in. I said 'wot even if they're the correct size and in good condition?' He says yes!
That's new to me! Anyone?
Pete
He's talking bxllxcks.
How does he know the DNO fuse size for EVERY home. I suspect he's going by those little pictures in the OSG!
Pete
Just another plank that's repeating what he has heard without questioning it.
I've heard loads of comical stuff off of so called electricians in the wholesalers.....the best advice seems to come from the ones with property maintenance plastered across their T-shirts/van.
He is absolutely correct.
Whenever I change a socket I always replace the wiring to it.
It's the same with light fittings, rewire the lighting circuit every time without fail.
:speechless:
:speechless:
Good man. You can't be too careful where electricity is concerned.
:speechless:
i always do s full rewire when I change an accessory.
I generally replace the tails for 25mm when I change a board, not that they need it as such, but I like to give things a freshen up.
Completely unnecessary.
I've devised a new method.
Strip out the cores from 10mm T&E and jam it in with the 16mm tails.
16 & 10 =26..... job done. :D
generally you need to replace the tails because the old ones are red/black. that will never do. what if a french electrician was the next man there. he'd hold up his hands in horror. oh, seems they did that in 1940.
It always puzzles me this. The OSG tells us to replace the tails for 25mm regardless. I have mentioned this to one or two Network guys when they have been at a premises fitting an isolator, while cadging seals. Most domestic supply cables are 16mm, so putting a 25mm tail in "in case the cut-out is upgraded in future" seems a bit daft to me, and they have all, to a man, agreed. This has been irrespective of if a few seals have fallen out of their pocket as they got into the van.........I suppose there must be a logical reason for it?
Does the OSG actually tell you that? I don't think so.
