Is that directed to me? If so then feel free to articulate what the duck you are on about, cos I am well n truly lost by your statement.....
I *think* the chap was making a tongue in cheek joke, as in "Sort it out properly? In this economy? Nooo! Surely the way is to just bodge it, that's what EVERYONE does these days... Sort it out properly indeed, anyone would think this was an electricians forum for proper advice from qualified people..." - I don't think he meant anything by it and certainly not anything aimed at you... I suspect that face to face the tongue in cheek sarcasm might have been more obvious. That's what I'm guessing was meant, anyway. I could be wrong! :o)
There have been quite a few sarcastic responses to this, for obvious reasons. If the OP has to ask such a question then the only conclusion is that he needs to get a spark in to do it. If I was to be more useful I could have made many suggestions but there is no point is there? I wasn't inferring anything about your competency at all, I think you missed the irony.
At this point, according to the OP's profile, he's not been back on since posting!
The 'safe way' would be to disconnect the cables, pull them out and connect the socket(s) connected to the one you're removing and reconnect them with an unbroken length of cable.
That's all very well but realistically could turn an hours work into a right mission in some situations with the associated labour costs, what if one 'leg' goes off under the floor to a downstairs socket and the other off to another room etc etc , connecting the two ends properly and safely out of harms way in a suitable enclosure is perfectly acceptable and professional imo.
I thought I was a bit slow on the uptake when it comes to sarcastic comments. I will try and be a bit more obvious in future. Anyway 10/10 you got it spot on Capt Mannering.
Probably a good idea - like I say it went well over my head, I'm one of the most sarcastic people I know, but it's really not that easy picking up on it on a forum.
Like most things it depends on the situation. In an ideal situation an unbroken cable would be preferable to joining the cable.
cables were jointed at the socket in the first place, so replacing the socket joint with a well made MF joint is no detriment. tin hat ready.
Yes, the description Connexbox have used could be considered misleading. Having just read the Wago instructions, in order to meet BS 5733-MF the WAGOBOX must be installed in a particular way, so it is not automatically compliant and it does not appear to have the “MF” symbol required by BS7691 526.3 (vi).
I am always keen to find new maintenance free accessories, especially as the Ashley connector blocks cost almost a fiver each. I will keep the Wagobox in mind.
In the real world, when ££££££ are king, you just do what you have to do.
stevieh,
NDG Elecs,
