J.C.E
On a rewire of a 1900's flat
what I think is the incoming bt line- its a old looking grey 2core 1mm cable (looks like bell cable)
was going to have my master here- then run 2x cat5 cables from here to 2 slaves.
before place gets plastered- thought it be a good idea to test it before place is plastered
purchased:
http://www.screwfix.com/p/mk-1--mas...99390156c974&gclid=CP_njo-S1c0CFSsz0wodkO4DHQ
the 2 core grey cable has no colour indications- so tried it in it 2 and 5 terminals (there isn't a a and b??)
either way I put in around in 2 and 5 with a phone plugged it- it just has a ingaged tone!
any help would be great
get your mulimeter on the pair. should read approx 48V d.c. it'spossible that the phone line is down, either cut off or faulty.
purchased:
Can you still dial out? It could be the phone lines set up for 1571 service and the engaged tone is to indicate there is a message. measure the voltage, should be around 50V DC.
Edit: Tel beat me to it
should be a pulsing dial tone if there are 1571 messages.
left now! but will do on monday
if the line is healthy etc- is what I done right and is that the correct master?
Some have the back bit for the incoming connections- then the top what goes on top of that where the slave connections go
you could just wire it like a radial to make second fixing easier. old telephones require the orange in 3 as well for a ring.
Waste of time these days all of the newer adsl / VDSL i-plate filters fitted to the nte5 master disconnect the ring circuit to reduce the line interference that affects broadband speed
Hum... on 2nd fix don't connect up your slaves until you have the BT incoming line confirmed, or Mr BT may be sending you a nasty bill.
Your old grey cable may be past it's best before date as BT now use a black dropwire if the grey incoming BT cable is to be plastered in the I would suggest you get BT into confirm it is ok before you plaster or install a conduit so you can route a new incoming cable to your master location. The old grey cable insulation is a known failure point on overhead incomers and can affect call quality and broadband speed
To avoid future problems and BT costs you would be better off using an BT NTE 5 master https://www.tlc-direct.co.uk/Main_Index/Telephones_and_Accessories_Index/NTE5/ as the design allows disconnection of the extensions and gives a test point to verify the incoming line when faults occur
The MK master you have has IDC connecters which only reliably accept 2 cables so your cabling configuration with three cables to terminate may cause problems if you use it
As its a flat it could have a big multi pair cable coming in to a plant/switch room and internal wiring to the flat up a riser. might be worth trying to follow the route back if possible.
Just popped in there today tested between the 2 cores and got 48vdc
and but a nte5 master (one with a and b terminals) on instead of the mk master
-but still engaged tone- tried dialing my mobile- but still just engaged tone
Just two flats in one property- up/down- i am in the upstairs- cable comes in by window from up by roof- looks like it just comes directly from pole...
Get the customer to phone BT and report a line fault.
