B
Barry White
@ Dan
Is there a forum clock anywhere?
I can see my posts are minutes old then eventually a time . I believe I have the settings correct to autocorrect the clocks going back (and forward next year) I expect loads have the settings wrong tho as its hard to check (or is it and I am missing something)
Cheers Mykey
The forum uses the server settings which auto correct.
After an hour it'll say a time. And the time will be accurate and take into account daylight saving. So as with your computer, you can save a word document at 11:59pm, then save it a minute or two later and it'll be saved at 11:01pm, and then when clocks go forward you'll save it at 11:59pm then 1 minute later you can save it again and it'll record a time of 1:00am or thereabouts.
We don't have a clock running on the forum because every device you view it on usually has at least one. And like with a casino, I'd rather you not know the time so you hang around and post more :D :D :D :D (that's a joke by the way).
The members are geting more demanding by the day, thanks button, clocks, what next a foot massage while you type.:D
They must be getting to much pampering lately!!
LOOK ON THE BTIGHT SIDE , GLENN. YOU MIGHT BE ABLE TO GET A GORILLA PEDICURE.
Can I have a foot massage please.... May help with my buggered up ankle... :)
You just need to act your age and keep away from these things!!
lmao that is brilliant
