I
Ian1981
A type b mcb will trip between 0.1-5 seconds at 5 x the rated currentSo Cmin is applied to both tables then? The OSG also factors in a temperature correction factor, that is the reason the values are different?
So 32amp x 5 = 160 amp
So 230v x cmin 0.95= 218.5 volts
218.5/160= 1.37 ohms
1.37 at 70 degrees
1.37 x 0.8 = 1.10 ohms
