Get an electrician to change it ?
move the neutral wire that curremtly go from the incoming supply to DB,
move it so it goes from DB to smart meter !
Where can he find some electricians chaps ???
anyone know ???
anyone know ???
The only slight issue is that it involves opening the cutout
anyone know ???
Pretty sure everyone here just wings it :/
Worked well so far:D
Been reading up on smart meters & if you change suppliers you need to change the smart meter again as the software is supplier specific . How smart is That !
Not convinced on that one. Surely a firmware upgrade at most. Can't believe a standard Siemens meter would need ripping out.
They are set up to work with ther own tarrif supplier rates and like NHS systems are not interractive so i've read . I wait to be corrected .
I call BS, but I am also willing to be corrected :-) I reckon they could upgrade firmware over the mobile network quite easily.
