Discuss Domestic Sprinkler System Help in the UK Electrical Forum area at ElectriciansForums.net
N
nlbhoy
I've recently 1st and 2nd fixed two new build small houses, the job is due to be signed off
on Wednesday.
There's sprinkler systems fitted in both properties, I've fitted Aico detectors throughout, and
had asked the contractor (who's a friend) what was needed for the sprinkler system, I was told
just to provide a supply, as the DB is right next to the flow switch this could be done easily.
After speaking to the sprinkler guy I've been told I should have interlinked them with the
smoke detectors which makes sense. But, Like I says I was told all I needed to do was provide
a supply.
What are my options here?
Does the sprinkler need to be interlinked with the detectors? it's a very small property, can
the sprinklers have it's own sounder? it's a bit late now to start making holes in finished ceiling
to run new cables etc.
I can't find much info regarding regs for domestic sprinklers, any help/guidance would be
appreciated.
Here's the info from Aico. You fit the switch module under the smoke detector base, or near by. The sprinkler don't go off when the smoke detectors sound, it's the other way round, the alarms will sound when the sprinkler goes off.
Ei129 Hard Wired Switched Input Module
This module triggers the alarms in a system if an external device is activated, such as a sprinkler system.
If you are installing a water mist system, as building control would never request sprinkler system in a house....the mist control unit has 2 detection inputs zone 1 & zone 2. Both heat detectors (not smokes) must activate to release the water mist.
So both heats are activated to trigger the system? Would this be a compressed air system.
Reply to Domestic Sprinkler System Help in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi Guys Recently finished a new build house, 2 levels/ 5 bed. Wired AICO grade D LD2 system throughout. LABC has come to sign off saying needs...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
