Discuss Domestic Sprinkler System Help in the UK Electrical Forum area at ElectriciansForums.net
just done sprinkler system for new builds, system being commissioned by others but some tight requirements.
1st they required their own board was not happy being on the non RCD side on high integrity board.
2nd from consumer unit to the sprinkler system required FP200 fire alarm cable for power.
3rd Aico smoke alarms wired as normal but with a relay card (input type) on one of the alarms so when interconnected it sends signal.
so we had to install second board just for sprinkler system.
4th we did not know at the time but water pressure for the houses & flats did not have enough pressure so a pump was required also.
just to mention Aico have two types of relay (they may do more) input & output bases the one we required was the input card, lucky my wholesaler had 3 in stock at another branch I had to go pick them up as I had bought the input ones not realising what relay was required.
I do however now have I think on email still instructions for equipment required if you need them I will try & find them.
Ei408
If you are installing a water mist system, as building control would never request sprinkler system in a house....the mist control unit has 2 detection inputs zone 1 & zone 2. Both heat detectors (not smokes) must activate to release the water mist.
Sprinklers m8ty, think we had 4 floors
Ei408
Thanks, that would be great.
The sprinkler guy gave me the spec sheet for Ei 129 hard wired switched input module. So I presume that's whats needed.
I think with Aico they do wireless so if you have only done twin & E to 1st detector then 3 core & E between you should be able to fit a wireless bass at 1st detector to wireless relay base.
not sure on that one drawing definitely shows a hard wire connection from relay through to the sprinkler head, I would not go down the route of wireless unless you clarify that with the guys/ girls who are installing & commissioning the sprinkler system might bite you in the a...
It was just that in the O.P. states does not want to start making holes in finished houses, it is the sprinkler that sets off smoke alarm sounders and I thought that it was allowed to wire smoke alarms interlink wireless if not Aico would not manufacture them.
I would take that on advice straight from the people who are going to commission the system before they get there, if anything like ours they are nationwide & travelled along way to commission if not ready you will be charged for a revisit.
Reply to Domestic Sprinkler System Help in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi Guys Recently finished a new build house, 2 levels/ 5 bed. Wired AICO grade D LD2 system throughout. LABC has come to sign off saying needs...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
