H
Hardwired
I have CK Modulo drivers size 1 and 2 that i use on Consumer Units but i'm wondering if anywhere does a size 3 for tails going into main switches. Or even vetter a size 3 for a torque screwdriver.
Anyone able to point me in the right direction?
Say Crabtree. The PZ / slot screw is a lot bigger than the normal MCB which i use a no 2 on and the rcbo which uses a no 1.
I've never seen a hex key apart from on a main isolator i'm talking about the main switch in the C.U.
just use a no.3 pozi tip in an impact driver. :mad:
My wera torque driver you can put whatever size head you like in it.
will this head fit?
Hardwired,
onions1066,
