All sorted!!
I disconnected my new socket from the socket supplying it. Tested at 500v on the 'faulty' circuit and I am now getting 100Mohms N-E, whereas before I was getting 0.1Mohms at 500v.
What throws me is I was getting 12Mohms at 250v on the 'faulty' circuit??
I replaced the new socket and it now tests fine and the gripping has stopped. What was all that about?
In addition 0.1Mohms wouldn't have tripped the RCD anyway? Also, when I tested at 500v actually in my faulty socket i heard a kind of sizzly sound coming from the socket?
Confused, but very happy it's sorted!
While the missus is watching strictly or x factor, pour yourself a glass of ale, find a magnifying glass, retire to your den, open up the back and take a gander.
Trouble is, when he does all the springs etc will fly everywhere, and he'll never get it back together again. Clever those Chinese. :)
It teaches all sorts of skills taking something apart, working out how the parts work together and then re-assembling to a working condition without anyone getting hurt. I found it a good way to occupy children when they are bored. Clocks, switches, circuit breakers, motors, oscillating fans, toasters, simmerstats, thermostats - obviously defunct before they do - the list is long, .
Only instructive thing I can remember doing as a child, was shorting out a spare car battery my Dad had, with a short piece of wire, and watch it glow & melt. :)
..and as a result you learned (and never forgot) about Ohmic heating, the phase states of copper and how they change with temperature, infra-red waves, energy conversion.....plus all the dangers of doing just that.
Engineering is a practical subject after all.
It's not to late to take something apart now for the shear joy of doing so. I wonder how many electricians have actually opened up an mcb, rcbo, rcd, hrc fuse, 13A fuse...if I ruled the world it would be done in college as part of their training
I opened up my faulty socket as Marconi suggested and I found a little man living in the neutral terminal. I asked him what he had been doing and he said he had planted some vegetables in the earth and had been watering them. Problem solved! o_O
Had a couple of beers and in a silly mood :)
What was the make of the new faulty socket?
p.s. I loved what you found inside it!
Crabtree. It's the first time it's happened so I won't blame crabtree just yet!
Here's a Crabtree double socket I had to replace FOC for a customer. Switches no longer able to be pressed into "on" position, and no power output on either half of socket. Been installed just over a year, had a reasonably high load: washing m/c plus tumble dryer, both running off one side of the double socket via a short 13A extension lead (as the double socket was too far away from the washine m/c and dryer). Terminations all good and tight, no sign of any thermal damage around terminals. Note the slight bulge near the left hand (as you look at the photo) earth terminal. Took it apart: plastic around switch springs had melted, meaning contacts no longer able to move.
Yeah, I'll be running my Crabtree stock down, I reckon.
