Drew34
Yesterday whilst doing my practical assessment (2365 level 2) I caused a bit of a stink.
I was working on a couple of 2 way switches with singles through pvc conduit.
As the training centre boss walked past he started over me having blue cable at the switches.
He kept saying 'why have you got neutrals?'
My response was ' I haven't. I'm going to sleeve them brown. Surly it's not neutral if it's not doing what a neutral should do it's just a cable until terminated.'
My tutor had no problem with this method.
Maybe I should have just smiled and pleased him.
Was I right?
Got to ask, why did you us?
I fed it through and realised what I had done so thought sleeving would be ok.
Maybe that#s why the Boss man was having a go at you.
Reactions: DPG and Des 56
I'm all for being put straight that's what learning is all about. To learn I need to be shown right. Centre boss says no but my tutor says yes. It's no issue for me to pull them and redo next week. Just after opinions on conflicting information.
Your input is needed as being new I've not earned the right to question these people
I would question both the Boss and the Tutor, if you are being given conflicting advice, then the Center is at fault. imo
The boss is the man but my tutor assesses me. Would have pulled it out but to be told it's ok just sleeve it.
Got the impression that they clash a bit and my silly mistake just added fuel to the fire.
Just asked the electrician I do bits with and I got a text back saying 'lol. You really are special'
If you get grief or fail, I would contact the Sponsor or the CP Scheme they are affiliated to.
Thing is I know what I did was stupid. However I've not decided to enter the industry to be a bodge artist. I'm in it for the long haul and one day would like to be known for being good!!!
the only reason we use blue with a brown sleeve is when using T/E where there's no option. in ROI, they use twin brown for switch cables.
Reactions: OldeSparky and DPG
Not quite sure what a CP Scheme has to do with it I think the OP is referring to the person in charge of the centre (Bossman) and his tutor.
Reactions: Drew34
I'm just stressing and unfortunately came here to rant. But on the plus side I know never to do it again.
Maybe I should have just said ' don't worry my mates an electrician and he's gonna change it when he's back off holiday'
  • Funny
Reactions: DPG and Rpa07
Sorry I must be getting the wrong end of the stick is this in a training centre or on site, if on-site why are you unsupervised.
From the point of view of compliance with the regulations it is possible to sleeve a blue single brown and use it as a line conductor. From a practical and good workmanship point of view it is not good to use a cable that could be misidentified; because you would be expected to use brown in this case brown should be used and this makes a safer and better installation.
According to BS7671, you can use whatever colour you want excepting G/Y, as long as you identify at the terminations.
I do a lot of work where there is a permanent line and a switched line. Usually one is brown the other is black. It depends on the site as to which is which.
Read my previous post
Please explain what the connection is to a CP Scheme.
IMO if the OP, who as it seems, has received conflicting advice, the training center's usually have some affiliation to a CPS member, example NICEIC approved, that sort of thing.
If he get failed for taking the advice from his Tutor, and it proves out to be the wrong advice, as in this case, I feel his recourse will be to contact the CPS and air his complaint to them, whether he will get anywhere is debatable, you have to agree to that surely, or maybe you don't.
I use twin brown when I can saves marking cable ends
problem with twin brown is you need to ID which is which, otherwise you have a 50/50 chance of L feed into L1 and switched L into C, at the switch.
Sounds to me like the training centre didn't want you to waste any more of their cable.
These training centres don't make much money you know
You Jest?
  • Funny
Reactions: AJshep
Yes the last paragraph was meant to be taken jestfully.
Although I'm sure that's what they would tell the OP if he asked.
Reactions: Pete999
Didn’t think it mattered really L or C and L1 are identified as live terminals
Didn’t think it mattered really L and L1 are identified as live terminals
It would matter if you had a 2 or 3 gang switch and needed to loop the L to the other switches.
Reactions: Rpa07
but then I wouldn’t have used twin brown as my switch would be mains fed with just a switch live and neutral to the light
Perhaps next time you could explain your reasoning with a little more detail, that would have avoided any misunderstanding.
Reactions: Rpa07
i prefer to use 3c/E for switch drops id new works. then you have L, N, S/L at both light/s and switch/es. makes it easy for retro fitting smart switches etc.
Reactions: Guitarist and DPG
I thought it was obvious if I had mains at the light then I’d use twin brown at the switch and it wouldn’t matter which way they connected to the light switch
What if you've got a point in a lighting circuit not identifying a sw L?
Bleedin' 'ell....easy for all these DIY ers.
Would that be a single gang or multi ganged switch?
Who's right? Hopefully me!
Drew34,
Pete999,
