hi guys I need to replace the chipboard that my consumer unit is fixed to, is it safe to unscrew the plastic front cover and unscrew the consumer unit ,remove and re screw to a new ply back board (the unit is from wickes about 15 yrs old so it has the rcd things) I wont be touching the wires just replaceing the wood its fixed to ,I work in the construction industry but I'm only a groundworker ! but I do know a bit of basic stuff but any advice would be appreciated thanks colin
Does the CU have an isolator between the meter and the CU so you can isolate the CU?
Can you post a pic of the existing CU and it's surroundings.
I'd say you should be fine but whenever you have the cover off make sure the whole board is turned off, is there a separate main switch between the meter and board, if so it would make for a safer job for you.
put a pic on here of the whole board wood be nice!
thanks for the reply buzzlightyea as requested pic of the cu
Is that double socket mounted on the board you want to replace?
How do you intend to keep the CU in relative position while replacing the board?
Are you happy with putting a screwdriver into a CU that will still be live?
think you'll find that the cables all come through the weetabix board into rear enrtyto the CU. replacing the back board would entail completely stripping and rewiring the CU, so you might as well go for a more up to date CU. need an electrician for that. the dreaded member "spoon" is local to you.
I think you would struggle to change the board without removing the CU as it looks like the cabling is rear entry.
Edit ... beaten to it by others.... again
hi the double socket is separate to the cu ,ive got an insulated screw driver ,my thoughts are cut a hole in a new piece of ply cut ply in half suspend cu from celling joist whislt i remove old one ,fix top section of ply to wall fit top screw s of cu to new ply ,slide bottom section of ply to wall fix cu to bottom ply ,does that sound possible or am i best getting a sparks from work to do a foriener?
buzz, you've already been sent to the death star's garbage crusher. your next mission will be to scrub out the reactor core ( whilst at warp 10, of course ).
