I trust you will as depending on what sort of light you are hoping to install the cpc will need to be proved.Thank you.
How can I tell if one of them is a Neutral?
I will of course ask an Electrician but just wanted to know if it could be done before I called one in.
Ho
Circuit Protective Conductor (earthwire)Absolutely. As I mentioned I wouldn't dream of attempting this but just wondered if it was possible to do this before calling someone in.
I have no idea what a CPC is i'm afraid.
Agree what he said^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^looking at that 2nd photo, without risking giving out incorrect info, all i can say is that it appears to have N at the switch, so the project is viable.
Could be three switch cables but I suspect one is a neutral.looking at that 2nd photo, without risking giving out incorrect info, all i can say is that it appears to have N at the switch, so the project is viable.
Basic wiring is the black is used as a "live" to switch power to the light outside and the cable runs from the light fitting unless they dragged the mains in via the switch to the light.Many thanks for the reply.
I am very uneducated when it comes to electrics as you can probably tell. But from how I see it, there are two neural wires ( black ) just taped together and then a third neutral which just has a plastic terminal on the end. Not sure if that helps you or not?
Just noticed the updated photo, looks like a neutral is badly connected together in the box, the only way to be sure is to get a sparks in unless you know how to use a multi meter.
BTW in your fusebox is there a circuit marked up as Outside Lights sometimes someone would run in a circuit (builder) in the simplest way.
Looking at your photo it appears that the two outside lights have been disconnected the supply live is common (live in to switch) and the neutral in a separate terminal block this is only an assumption and needs to be verified as well as the earthing arrangements but on face value.
Educated guess....L connected in switch, N in connector, others outgoing L+N's, disconnected.
Q. Why tape the unused outgoing neutrals and not the lives?
Who knows? That's the question.
