WOOF, WOOF.
images
I like lathe and plaster, It brings out my ingenuity... the customer thinks im a demi god and proper professional when they see whats inside the wall and how i insert little bits of timber to strengthen the cuts lathes, to then affix or install box for a new accessory.
They usually ask me ,politely. to leave when they see the size of my tool.;)
and before i get any smutty comments, i'm referring to a 110V makita recip saw.
Don't you dare! Behind skirtings is the work of the Devil!
Mind you...it does get you out of a tricky place now and again:)
I made a tool up for getting behind a skirting boards, still have it hidden away with my pyro tools........
is that your chastity belt key? ( skirting... skirts).
I've used 20 minute rapid set tile cement recently - to get me out of ... a hole (sorry - best I've got at this hour).
Be wary of using bonding if it's not a cavity wall. That stuff acts like a sponge to damp and moisture...metal flush box will be rotted away in next to no time and along with it any tiles or the like.
Seanofakkad,
pirate,
