Hi
I was just after some pricing help/advice as I’ve been asked to price up for a kitchen rewire and as I’ve just gone on my own so is one of the bigger jobs I’ve quoted so want to get it right.
The kitchen will be empty and they’ve asked for a CU change (requested Schneider easy9 12 way), 10 new double sockets (using existing ring but they want existing sockets moving) 12 downlights (8 in kitchen 4 in utility) separately switched wall light, separately switched under cabinet lights and plinth lighting. A new cooker circuit and cooker connection point (20m in total)
Obviously will be tested/notified etc
All work to be carried out from below and patching ceiling before plastering.
They will be provide socket fronts and cabinet/plinth lighting
Do you guys generally quote per point and work it out that way?
What would be a very rough price in your guys opinions?
All help and guidance greatly appreciated
I would price the job est £1,500.00, if they are providing some materials ,you are running a business.
had a customer rings up to day ,what is you daily rate .answer .
need to see the job .me to customer are you a builder ,yes.
I will be supplying the materials., me .on your bike.
What if it's TT? I usually fit Dual RCD board with up front 100mA time delayed RCD. 95% of my work is with TT, lost interest in trying to source DP RCBO's or SP Switched Neutral RCBO's at reasonable money.
Nothing wrong with a 100mA time delay on a RCBO board on TT IMHO
my rough price would be £1400 - £1500
I'm generally in agreement with the price estimates.
As you are doing a kitchen.
Rule number 1. Do not start ANY work until you have a 100% confirmed and signed by the customer FINAL LAYOUT with exact dimensions of every thing. This will include the EXACT name, model numnber and specification of each and every electrical appliance that will be connecting to your electrical points.
Get confirmation as to who will be making the final connections, otherwise you'll be on your hands and knees trying to connect up a Quooker or a waste disposal unit long after you thought you had finished (these things dont go in until after the worktop is installed).
Think long and hard about how the cable runs will work.
Example: The customer specifies colour changing LED plinth lights all round the kitchen. How are you going to get the 4-core cable to leap over the doorway, past the hob, to the island unit.
Example: Customer wants under cupboard lights to be controlled by separate switch by the kitchen door. How you going to do that?
And I absolutely agree with this comment
<customer says>I will be supplying the materials., me .on your bike.
Thanks for all the replies so far, regarding the pricing I’m very similar to the prices you guys have mentioned.
The switches for the lighting are going back the existing light, the plinth lighting are all in one run, and 2 runs for the cabinet lighting
