Discuss Lighting Transformer - requires earthing? in the The Welcome Forum area at ElectriciansForums.net
Hi E.F.
I am replacing 3 lighting transformers in my kitchen.
The existing ones plug into 3 x main sockets which are on the AC mains circuit via a light switch and are earthed.
The replacement transformers have no earth connection - do I need to earth the new transformers? If so, how?
It's a DIY project, any pointers appreciated.
Thanks,
Simon
Manchester
Does the new transformer have a logo, a square within a square? if yes then it's double insulated and doesn't require a cpc.
Hi E.F.
Thanks,
Simon
Manchester
God help us all
plenty electricians in manc area could wire this up properly 4u. lights fed from 3 13A plugs via light switches is so Romanian.
Hum ..... lighting transformers in 13A sockets ..... op could you post a picky of the new transformer ?
And why not a like for like replacement?
as the sockets are out of the way and not likely to be used for anything else, go with murdoch's advice. fit plugs to the input side of the PSUs. just won't have an earth connection in the plugs. job done.
Hi George,
The sockets are hid on the top of a cupboard and are dedicated to the transformers, nothing else.
Would using an earthed transformer be a better alternative?
Thanks,
Simon
Still not good practice though.
Also note what I said.
What you have are not transformers (whatever the suppliers say) they are electronic switch mode supplies.
Are these 13a sockets wired on to the lighting circuit via a light switch? If so that is bad practice. 13a sockets should not be on the lighting circuit. Think what would happen if someone plugged the kettle into one of them.
Also note what you have are not transformers (whatever the suppliers say) they are electronic switch mode supplies.
Maybe bad practice in your opinion, but far safer for a DIYer to be fitting a plug than having a go at altering the fixed installation.
In this situation it really doesn’t matter what you call the device, it has no bearing on the OPs question.
I may have misread this but it sounds like the OP has already altered the fixed lighting circuit, to add a socket.
Ok Winston. You need to take this up with the manufacturers and make them stop printing the wrong word on all their products.
13a sockets should not be on the lighting circuit. .
Winston, stop making things up. BS7671 specifically ALLOWS BS1363 sockets and FCUs to be connected to lighting circuits.
If you do not agree with the regulations then you need to join the committee and lobby for changes that are in line with your strange logic.
Why 'Winston'? Isn't the OP's name as per his name.... or is it like 'Snuckums' ?
He inhabits another electricians forum under that name, and winges on and on about devices that convert from 240v to lower voltages not bring transformers ( they must be made of laminated iron to comply, you see).
He also goes on and on about his belief that sockets are not allowed on lighting circuits (they are).
He has been close to a ban () on the other forum. Now, I may be wrong, but it’s too much of a coincidence that these two specific issues are being soapboxed by this George.
It’s a pity, I came over here to get away from this.
There are other electrician forums???????
This is my forum. There are many like it, but this one is mine.
This forum is my best friend. It is my life. I must master it as I must master my life.
Without me, this forum is useless. Without this forum, I am useless. I must answer the questions true. I must be sarcastic to my enemy who is trying to be sarcy at me. I must shoot him down before he shoots me down. I will...
This forum and I know that what counts in life is not amount of Thanks, the noise of whingy old men, nor the Likes we make. We know that it is the amount of posts that count. We will post...
This forum is human, even as I, because it is my life. Thus, I will learn it as a brother. I will learn its weaknesses, its strength, its Forums, its accessories, its lack of Thanks buttons. I will keep this forum clean and ready, even as I am clean and ready. We will become part of each other. We will...
Before Dan, I swear this creed. This forum and I are the defenders of the universe. We are the masters of the plumbers. We are the saviors of the DIYers.
BOLLOX.:D:D:D.
Full metal jacket lol
My name is not Winston. Sadly manufacturers are ignorant and obstinate.
My name is not Winston. The regs are sometimes wrong. That is why there are 18 editions and upteen amendments in between. No doubt one day an amendment will come in banning this bad practice.
Must be your twin brother then.
It doesn't change anything else though. An electronic transformer does what it says on the tin, and sockets are permitted on lighting circuits.
I don't have a brother. The picture in post 3 shows a plastic box (not a tin) and has no mention of the word transformer.
I never said sockets were not permitted on lighting circuits, I said it was bad practice.
.The regs are written very poorly. That is why there are 18 editions and upteen amendments in between. No doubt one day an amendment will come in banning this bad practice.
Hum .. altered that first bit for you
As for "banning" 13A sockets on lighting circuits - who are trying to kid ............. best you stop the chinese supplying transformers for items such as under cupboard lights with 13A connections
Reply to Lighting Transformer - requires earthing? in the The Welcome Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
