I can see everything wrong with him fraudulently using the NICEIC logo and forms which is what using them outside of scope would be doing. Presumably non-domestic forms aren't even made available to DIS registrants.Providing your certificate contains the same information as is contained in the model forms in BS 7671, then you can create your own. I have an Excel spreadsheet I fill in and print for minor works.
You might also want to check with your insurer that your covered for work in commercial properties.
f:0
