K
Kimmy
Hi
In our living room the lights runs off a lighting circuit. 3 plugs which use 3 round pin plugs for lamps.
One particular plug has an extension lead attached. Its a single socket 5amp 3 round pin box. I would like to increase the number of items plugged into this.
Would it be possible to change the plug on a standard 6 plug extension cable to a 3 round pin plug, connect it to the 5amp box and then plug items in as normal, i.e the outside light, another lamp, charger for macbook and a aroma diffuser.
or use this:
13 AMP 4 WAY EXTENSION LEAD WITH 5A BS546A ROUND PIN PLUG SHOP HOTEL PUB 500mm | eBay - https://www.ebay.co.uk/itm/13-AMP-4-WAY-EXTENSION-LEAD-WITH-5A-BS546A-ROUND-PIN-PLUG-SHOP-HOTEL-PUB-500mm/231803021964?hash=item35f8896a8c:g:xVMAAOxypstRX8hM:rk:1
f:0
It says this item is 5a max. Would this mean that the items I want to plug into the extension lead would over power it?
Ideally I would like an extension cable with switches on it as the main switch on the wall works the outside light and the other items would not be on all the time.
or use this:
f:0It says this item is 5a max. Would this mean that the items I want to plug into the extension lead would over power it?
