S
Steve Evans
MCB down stairs light circuit.what kind of fuse is it bs3036 or mcb?
then its time to call some body up that have the experience for fault finding .MCB down stairs light circuit.
This happened about the same time the bedroom carpets were fitted so lots of banging and vibration must have loosed a wire in the junction box, not looking forward to opening up the ceiling as it's artexed.use a snake eye through the hole where the light is.maybe finf the JB that way. otherwise, it's holes in ceiling or bedroom floorboards up.
Trying to find a junction box by cutting the ceiling is a bad idea. Usually they are fixed in position facing upwards, so locating it from underneath isn't going to help you.not looking forward to opening up the ceiling as it's artexed.
I think that is unlikely. If it is wired to a joint box it will most likely be one central joint box for all of the lights on the circuit rather than a box for each light and switch.
yes 2 red wires into the switch and 2 blacks in a connector block. Wouldn't a junction box be screwed the the side of a joist?Trying to find a junction box by cutting the ceiling is a bad idea. Usually they are fixed in position facing upwards, so locating it from underneath isn't going to help you.
Are there just two reds at the switch or are there two blacks in the box which have been joined together?
Okay, you probably don't have a joint box then. It is loop fed at the switch. What are you testing between at the switch?2 red wires into the switch and 2 blacks in a connector block.
Thanks I feel like we are getting somewhere, tested the 2 red wires and fitted a new switch. I have checked most of the down stairs light switches for a loose wire tho.Okay, you probably don't have a joint box then. It is loop fed at the switch. What are you testing between at the switch?
If there is no power at the switch then there is possibly a broken connection at the previous switch on the circuit.
I think they used the existing strips and gripper rod.Professional gripper rod comes with the fixing nails already in the wood(which I assume they used). They are not long enough to go right the way through a 'normal' floorboard.
I'd be much more concerned about what length screws they have used to fix down the threshold strips, maybe nicked a cable in a notch.
Thanks, Not sure what you mean, 'red wires into the blacks' and 'red onto cpc'When you tested at the switch did you test from each of the red wires onto the blacks in the connector block? Also you need to test from the reds onto the cpc (earth) connection as it may be a broken neutral connection either in this switch or the previous one.
