N
needsomeadvice
Hi
Does anyone know of a weatherproof simple on/off timeswitch and Switched Spur thats available? Its going to be undercover, so not in direct contact with rain/sun etc but there will be moisture.
Welcome to the forum mate.
What is the timer switch switching? Max amps needed.
Regarding the 'Switched Spur': Do you mean something like this?
Yeah, the only thing is it needs to be pressed whereas i just need it to be automatically switched on via the timeclock.
Thanks. Yeah the IP boxes might be the way to go. Ok to then put standard white plastic accessories in it? I'm guesssing thats the whole point of it?
If you don't need to physically switch it then why can't it be mounted nearer the light? Then no need to be waterproof.
