M
mhm
In the NIC Snags and solutions book (ISBN10- 0-95310589-x) on page
four there is a diagram of a single phase consumer unit instalation.
Going from right to left there is a DIN mounted master switch followed by two busbar terminals conected to each of the RCDS. I would like some of them but have absoluty no idea what there called?
Thanks,
Tom
It's not a RCBO.
It's effectivly a DIN mounted terminal block with the busbar going in the bottom and a screw down connection in the top.
Sounds like the straight through neutral connector that comes with 125A TP incommers.....
Although I'm sure your trying to help, I don't want guesses!
Its not a un-fused connection or a nutral bar.
Hager do an MCB profile 100A rated terminal block. (cat ref KR50U) just a way way of taking a supply straight off the busbar to a cable. Aint got the book but it sounds something like this!!!
Thanks,
Tom
Scan the image and post it on here so we can all have a guess:cool:
Thanks Steve, I'm Pretty sure this it it. I have ordered 10 and will let you know when they come down.
Tom
