Right this is what they have now, I’ll do a drawing of what I think it should be and you guys can correct me if I’m wrong? Or any other solutions? Or if anyway has a drawing would be must appreciated haven’t really touched key switches I know it’s a normal switch basically or contactors
To keep it simple think of the test/key switch as the main on/off for the circuit.
RCBO to key switch-leg 1
I would be happy to post a wiring diagram, would this fall foul of no step by step instructions rule?
Strima
The switched live side feeds direct to the led geartray 230v via the pins and the emergency/perm side go through the module witch should have a built in battery witch would power a second set of led,s on the geartray via the battery in the event of a power outage
There are multiple ways of doing it, depending on exactly what function you want from the manual on / off switch and the photocell override switch.
but this is one way it could be achieved.
Strima
That just seems like a lot of faff...
To be fair all the 2D EM fittings I've dealt with were solely 2D with no additional LED lamps hence my comment.
That looks wrong to me, the p/c override and supply for the control.
depends on what you are trying to achieve.
if you want the lights
perm on, turn manual switch to on.
automatic, turn manual switch to off with over ride switch on
perm off, turn manual switch to off and over ride switch to off
