He has asked for work to be done,what he does with what you provide is his look out
I don't see how anyone can be responsible for whatever work is then carried out
Appreciate what you are saying Des, but is the client not paying for the installers expertise and advice? after all what would you say if you told the Tyre fitter yo put duff tyres on your car and it failed the MOT? To be honest I can't see the logic of your reply.
I have very often gone into industrial units,supplied 3 phase and single phase outlets,perhaps high bay or fluorescent lights,used differing methods of installing,conduit,pyro, armoured, clipped,whatever was wanted and complied it got installed
What I would not do would be refuse to install because "they may" be used for purposes other than what they are not intended
I have no problem with giving advice and would always do so,but what someone does with their business is their responsibility
Having said that,if I were then to report on a installation that I had fitted and it was being used inappropriately I would also make a unsatisfactory report
My responsibility is not to make decisions on the working environment of other businesses
Just to add,this is my own personal opinion.its not meant to be argumentative,it can be accepted or rejected,that is your own prerogative,what it does not deserve is insult,thanks in advance
Des, not sure what your inference to an insult means, I for one never intended to insult anyone, just couldn't understand your logic, if you mistakenly took my response as an insult than you to have misunderstood my reply, no insult was/is intended, perhaps you could clear up your inference for the sake of harmony amongst Forum members.
My apology to you Pete if it seemed aimed at you,it was not meant for you or your post
It was because of what I experienced on this forum last year with the EU thread,that thread went way beyond what was being discussed,I was personally getting too much abuse simply for having a different opinion to most others.I have a opposite view to most on this thread and just slipped that in at the end for the sake of harmony :)
