Sorry for being such a simple question but just need help attaching wires in correct location. Right now have a simple off/on switch and want to replace with a timer. The switch now controls a light and it is the only one connected for it. so somewhat simple but.....I am just not sure on which to connect where off the switch to the timer? I attached photos so if anyone can help me out, greatly appreciated. Thanks.
we have a few US members. they may be better to advise than us UK sparks. as it looks, you probably need a neutral to the timer as well as a line in and line out. my first advice would be to contact an electrician.
Thank you very much for the help. Will do so.
Since you are from the USA go to your local electrical parts house and they make so many different timers it sounds like all you need is a mechanical timer which will wire up the same it has seconds minutes and hours just select how long you want it to run turn the knob and it will time out and then disconnect the light
Nobody cares about what you say and keep your bad attitude to your self. We have some of the best electricians in the world
And with that sort of unwarranted remark this forum could be losing a contributor
Also please leave insults directed at the English in the hands of the Scots Irish and Welsh
They have much more experience at it and can do so without causing offence ;)
Just read post #7 and that was uncalled for
