It is achievable to have consumer units in each room. However, you may well require an AFDD and possible SPD costing hundreds for each consumer unit. For this reason it would be better to have one central consumer unit supplying each flat with possibly a din rail meter for each flat. For instance one landlord I recently did some conversion work for had a bill for £6000 electricity. The tenants were wont to leave heaters on and disappear off to sunnier climbs for a few months. At least you could switch off the supply from a central location if needs be if you can't enter the room. Tenants can be most interesting in the way they treat property and equipment. It may therefore be safer to have the consumer units in a central location.
If the Local Council, who will be leasing the HMO have stipulated each room must have it's own C.U, then each room must have it's C.U. or go find someone else to lease it to.
Any discussion about alternative ways of doing it is pointless.
It doesn't matter whether it's unusual or over the top or if other extra work needs to be done as a result.
If the Council wanted 2 rooms painted Blue, 2 Pink and 2 neutral colour, then that's what they'd need to be.
If the first electrician has said it's not required or unachievable to have 6 CU's and 1 for communal area's, then the O.P will have to find one that can achieve it.
Depending on where abouts in London it is, I would be more than happy to give you a quote.
mineral,
Leesparkykent,
