and this works the way you want it to?
Im worried where the reds into 2way are going
Also, you need to link the metal faceplates to the back boxes with a little green/yellow to earth them.
It works just as before both hall switches independently on and off and bathroom on the other switch in the 2 gang working also the switch plates already have the earth in there should of shown that really
[automerge]1590317544[/automerge]
Also the 2 reds are the link in COM as they are the perm live all lights in the flat work and I haven't electrocuted myself so win win haha I've only got 2 switches to change now and they are simple that one just threw me off
image-jpg.58357
Bit of a rough drawing but this is how it should be wired,ensure all the wires are identified as live using red tape and the single hallway switch should have the com terminal going directly to the light. The 1 way wire should terminate on the second single switch to that 1 way wire - the same for the 2 way terminal as in the drawing.
The com terminals in the double switch should link Together and the permanent live also terminates into one of these.
As mentioned, ensure the switches are earthed to the back box which should be earthed already and that this wire is identified with green and yellow sleeve or tape
image-jpg.58357
Yeah this is what I've done just couldn't understand that link it was in the wrong place all together but it's all neat and tidy and now marked with the correct tape and the earths were fine didnt need to touch them
Thanks everyone as soon as you guys mentioned that link I knew thanks for all you're polite help if I could buy you all a pint I would
