Please post pictures of the damaged plug, outside and inside showing the connections (unless it's a moulded plug that can't be opened.) Otherwise we don't know what kind of problem we're discussing, if any.
Havong phpne problems sorry im late..
Its a heavy duty infra red 350watt brooder
And a poultry green 400watt sodium supliment lamp which goes on a ballast. The infra red heats more somehow lol. They dont cook lol at 3ft i getv35 degree in the brooder and it keeps the roost warm same time without using heat bads and bulbs in there. The hens. Like to smash about and damage lights in there anywho lol.
Anyways on to the problem
I got my soket testwr which says the socket is fine.
I dont like how dirty it is. I am about to put a 2pole in and as u can see earth is in a single jacket.. Am i right in thinking i dont need to but its better to reshrink 3.mm each and use both poles?
Now the plug that was in the timer from ballasted light. Where the plastic is is where the brown was mirroring the brown from the timers plastic.
Timer says all works too.. And has no damage internally?
[automerge]1590692255[/automerge]
Been a hot day my daughter spending all her time with the chicks at the moment warmer outside than in the shed at the moment night time there in my house the lids want them to stay there hahaha Screenshot_20200528-194126_Messenger.jpgScreenshot_20200528-194056_Messenger.jpg20200528_175716.jpg20200525_221909.jpg20200528_100453.jpg
In my opinion that's a bit of dirt, or maybe a fly or insect, that has got trapped between the plug and the socket, not any kind of burn or overheating mark.
The socket is cracked, just swap it out for a new one and carry on.
I thaught so too but didn't wana say myself.
Thankyou somuch you guys saved me somuch.
Have more questions coming soon hehe as il be making a bandsaw shortly too hehe
[automerge]1590698442[/automerge]
As per the earth socket 2 pole..
Do i seperate the double ewrth and re sleve them to both poles?
So leave doubled in 1 and run a little wire in the other to metal case? Dont see what that does but manual looks like that?
[automerge]1590698560[/automerge]
Connect it exactly as the old one is, reds to live, blacks to neutral, both earth's to one of the earth terminals.
An earth link to the back box is not strictly required but a lot of us would consider it best practice to fit it.
