The rest of the circuit is 3 plated.I guess I would of called that 2 plate method very interesting.
And with the 2-ways it's still 3 plated.
Three plate terminology is actually referring to the ceiling rose (3plate), IMO this method is outdated because simply not used very much, with modern light fittings, led , etc, all new builds down this way are fed at switch box. En54 would be moaning lolView attachment 59128
I assume you mean like pages 1 + 2?
Maybe someone can enlightenme what does the word plate actually mean? I assume it's the number of wires?
Sorry Mark, are you not understanding my post?, anyway 3plate is the 3 plates of the ceiling rose ie connection points, nothing to do with the number of cables, I know you have feed in, loop feed, switch wire 3 cables but that is irrelevant.You've thrown a spanner in the works there don't know how you would label that?
it's the same as 3 plate wiring but at the switch.
hasn't Australia been using Loop at switch for a long time? do they still call it 3 plate?
That is 2 plate.yes sorry, shame on you just had all lose ends tidied
what name is suitable for Loop at switch? - 2 plate or 3 plate or just loop at switch?
Interesting in the UK we call ours protective multiple earthing (PME) for TNCS but it's uncommon to have a consumer Earth rod at the property as-well.
Would this require at extra earth rod mandatory? or you make a decision based on Ze reading.PME is the most common type of TNCS supply in the UK, but it is not the only type of TNCS supply.
A TNCS supply can be installed without it being PME.
