Of course those stating the circuit should isolated & locked off are correct. But that's not easily achieved in some if not most domestic properties. I've read many times of members criticising other members for not leaving householders with power, some houses have only one RF.
Suppose the only correct way, would be to return to site just before the plasters start, and isolate, but then you might have to keep returning when they want to mix up some more muck!
I've used Yoozybox & blank plate like @telectrix before now, but either found them smashed, or the plasterer bumping his gums, that they got in the way.
What about Blank it?
On some rare occasions, I have left people with an energised circuit that fall short short of the standards required. This is normally due to an out of hours call out where the correct part is not available. I am not daft and understand that at times we do not rigidly follow all the rules at all times.
However, putting the plasterers life at risk by leaving poorly protected cables live and within an inch of his wet steel trowel is a step beyond where I would be comfortable.
This is planned work, so make a plan.
Look for other options
Lighting circuits, can they be isolated at the rose for the room in question, if not maybe in the adjacent room.
Worst case, some temporary lead lights for the areas that need to be lit.
If someone is seriously injured or worse due to your failure to isolate or protect cables then the court is not going to accept that you left stuff on so the tv could be left plugged in to its original socket.
For ring circuits you can change the OCPD to a 20A device and disconnect whichever section of the ring is necessary. The rest of the circuit will remain live as two radials.
Agreed,
Like I say, planned work.
MAKE A PLAN
There are many scenarios that you might come across
It may at times be more work or a little inconvenient,
but gone are the days when you could get away with taping up cables and putting a warning live cables note on them (if it was ever trueley acceptable)
With some thought, it is not required to leave hidden dangers around site, we can use our brain to come up with a safe solution.
I always tell the plasterers that the cables are live even when they are not in an attempt to stop them filling the boxes and leaving a smooth wall and I have to find and clean out the boxes.
Alternatively it's box extensions and a blank plate fixed with security screws to stop the plasterer getting clever and removing them to make it easier for them, get some moans from the plasterer but am I bothered
Reminds me of a job about 35 years ago wired an 18 gang grid box on a commercial new build all the cables were marked with various nicks to identify them, the plasterer decided the cables were to long and cut them back so he could get them all in the box, the end result when we got back on site was one wall plastered completely flush with the switch box and 2 2g sockets lost in the plaster told the plasterer to find the boxes only to be told that was my job the ensuing argument as I was about to attack the wall with a hammer brought the site agent out of his office, while he was trying to mediate the project manager turned up on site once he was up to speed with the problem he called one of the plasterer's bosses to site once he found out that he was going to be back charged for belling out all the lighting cables and they would have to make good any damage finding the boxes the plasterer was told to get all his tools as he was being sacked with immediate effect
Bit like the artexer filling the ceiling roses up,after he asked for them to be fitted,so he can make a nice swirl around it, how dated is that now.
Dated enough that he is probably a 'specialist' and charging a lot for making a mess of a perfectly good ceiling, unlike the days when it was all the rage and every plasterer did it.
It's only become specialist as the artex has killed off most of the plasterers doing it as it contained asbestos possibly up until the late 90's. I knew a few plasterers that died with asbestosis all of them did the textured ceilings and walls without knowing the risks until it was too late
When I've had to leave live cables in a flush mounting box, which will be plastered, I've fitted a metal cover plate that is cut slightly smaller than the box, so it recesses in as far as the lugs. So there is no access to the cables inside. The cover plate cut from thin sheet metal with tin-snips, and I retrieve them afterwards to reuse.
Metal plate, live wires, and Plasterers, a bad mix Mate.
