DurhamSparky
sorry just wanted to get you all in here to post your comments!! has anybody ever caused an electrical fire...! or has any body's equipment caused an electrical fire!!
seen an alarm panel catch fire once,while i was standing there wondering what the fault was,bang up it went...guess i found the fault,stiil dont know why it went up except it was old..
oh well at least you can explain to the customer with ease when you tell him he needs a new panel
Blew a dimmer up, lots of smoke but no flames, probably would have caught if I had left it.
Not telling how I did it.........PLONKER!
Was working in a place that makes the autogleam car rags for my old firm, on a breakdown, my boss took the contactor out of the casing and was "playing" with it on the floor while it was still live. All i heard was a crack, contactor arc'd and sparks flew everywhere, igniting what I can only describe as the byproduct of the cotton rags. (it was like a soft dust/fluff but it was everywhere)
He jumped up trying to stamp it out, but by that time it had already made it up the machine and onto the top of the metal trunking and was heading in all directions. It was like something out of a cartoon when they light the fuse wire for the TNT!
I raced over and grabbed the fire extinguisher and ran about like a lunatic. Obviously had created abit of fuss now. The factory bosses came out to see what was going on so my boss grabbed the extinguisher and just looked at me and said 'he was working live wasn't he....tut tut'
Typical...
I would have knocked him out there and then. What a -----.
I was working on an Industrial dishwasher. No Instructions on unit but found the final rinse element fas blown. Fitted the new 6kw 3Phase element and started the bad boy up.
Well it turned out that tank only filled when the machine had been running for a few mins and colk water hitting that size of Hot element causes a HUGE bang. Fortunatly gaffer and manager had seen what i had done and were aggreeing what i was doing was right before we got deafened.
Not caused a fire but managed to flood three floors of a building with a good few thousand litres of water when I was installing some comms cabling took out 5 lifts and the post room and to cap it all some one else got the blame
Well at least there will be no chance of fire with all that water not quite came close when the main neutral terminal of a buss bar had split and i hadnt noticed it so the connection appeared tight but was infact loose ,got a tad hot it did and had to replace the whole board on a sunday to which was a swine
seen one where DNO had fitted new meter and crossed polarity. fault on immersion heater apparently blew fuse, but fuse was then on neutral. house burnt down
Top Tip.....dont use WD40 instead of contact cleaner without wiping it all off first before switching in a big load!!!
zippo lighter fuel is even better!
had a report of "Flickering lights first floor" went and witnessed full first floor panel flick OFF n ON (800a ) interuptinf fridge compressors lighting ect ect ect checked supply 2 of 3 phases ok 3rd phase was wavering 418-375 checked main panel ground floor found sub main sw to be VERY hot to touch (800a HRC fuses) got permission to turn off (stor manager was a masterbation expert) founr main busbar joining bolt snapped only busbar to busbar connection was pressure not quiet a fire but very close ( panel manufacturer sent someone up and including stuff from van measurung busbar fitting it rebuilding covers repacking van 60min n they were off )
