- Dec 18, 2011
- 5,378
- 6,731
- 405,788
- United Kingdom
I have perhaps done 6 rewires now. They are hard work and I wonder if there are ways to make them easier as I have another 2 much larger ones (3 and 4 storey houses) coming up.
I typically take around 2 weeks for a 3 bed house. This is working flat out (by myself) everyday including one or 2 Saturdays and I feel that is a little longer than most of you would take, or is it about right?
I have just bought the metabo mfe40 wall chaser and hopefully that will speed things up. Are there any tips for using chasers? I'm guessing they just make nice neat notches either side of the chase which you then remove with an SDS chisel? Do you always then use oval conduit which you secure to the wall with the oval conduit holders or is there a quicker way?
Cheers all and hope you are having a relaxing Saturday!
Ps.. I'm awaiting the arrival of the triple blade for the metabo, anyone use it yet? Does it actually take out the middle of the chase well?
pps.. What size conduit do you generally use for 1mm, 2.5mm, 6mm, ring etc etc?
