Guest viewing is limited
HappyHippyDad
Supporter
I have perhaps done 6 rewires now. They are hard work and I wonder if there are ways to make them easier as I have another 2 much larger ones (3 and 4 storey houses) coming up.
I typically take around 2 weeks for a 3 bed house. This is working flat out (by myself) everyday including one or 2 Saturdays and I feel that is a little longer than most of you would take, or is it about right?
I have just bought the metabo mfe40 wall chaser and hopefully that will speed things up. Are there any tips for using chasers? I'm guessing they just make nice neat notches either side of the chase which you then remove with an SDS chisel? Do you always then use oval conduit which you secure to the wall with the oval conduit holders or is there a quicker way?
Cheers all and hope you are having a relaxing Saturday!
Ps.. I'm awaiting the arrival of the triple blade for the metabo, anyone use it yet? Does it actually take out the middle of the chase well?
pps.. What size conduit do you generally use for 1mm, 2.5mm, 6mm, ring etc etc?
Simple answer is get an electrician's mate!
Yes, that is half-joking as it is a big commitment to employ others. But I expect that having another competent (or even semi-competant) person to feed cables through, help holding stuff for alignment/drilling, fetching stuff if you are up to your elbows on a difficult bit, etc, would speed things enormously.
You're absolutely right PC, and I expect it would speed things up by more than double making it very worth while finacially. However..... I love working by myself, dancing along to the radio, answering back to Jeremy Vine and occasionally concentrating very hard on a very tricky bit, all of which wouldn't be quite the same with someone else around :-)
You're absolutely right PC, and I expect it would speed things up by more than double making it very worth while finacially. However..... I love working by myself, dancing along to the radio, answering back to Jeremy Vine and occasionally concentrating very hard on a very tricky bit, all of which wouldn't be quite the same with someone else around :)
You need to see if Jeremy Vine wants to re-train as a mate!
Have a look at this, go from about 5 mins 20 secs in...
Rather than employ someone could you pay for a mate from an agency for 2-3 days? Just to get the cables run in as that's always the tricky part on your own- up and down stairs a hundred times and them in and out the loft for the lights! Don't know how expensive it would be or even if you can get labour for that short a term but then you could carry on rest if first fix and then second fix by yourself if that's what you prefer.
25mm oval fits perfectly in the chases. Either screws or nails to hold it back. Much easier than capping.
Best way to speed up is to get some help with running cables and chasing especially.
If the place is empty I generally spend a morning marking up on the walls where I want the chases and boxes etc then sub that work out to someone on price....then come back once it’s all cleaned up ?
Now I'm beginning to get a complex, you have three Like's for the above post and I said near enough exactly the same in the post immediately above and did not get one.
If you do regular re-wires 100% get a lad / labourer in to do the chasing , boxes , drill out joists etc a few days in advance. Let the dust and dirt settle.
you then rock up and can wire , box , tube and stay nice and clean...
I was just looking at that video yesterday! I'll give a review myself on here in a few months when I've used it a bit.
I may think about that as lots of you seem to say the same thing, i.e get help.
I recommend learning a few emergency plumbing moves before breaking out the chaser, just for when the inevitable happens ;)
Definitely! I have no idea how to fix a pipe if I go into it. Done it twice now and each time I've had a plumber on hand, but one day........
Are these lived in or empty property rewires you have been doing
A mixture.
Chase out, oval conduit and secure with screws just pinching the oval.
Why not use the conduit clips Lee? It would be the same time to screw a clip in as to just screw a screw in?
Why 25mm? I'm guessing 2 x 2.5mm fit in a 20mm oval?
5 days for a 3 bed house.
1 Power off - all fitting removed- with hammer etc. no fiddling with screws
2 all chases done
3 all cables in
4 all accessories back boxes fit and plastered in
6 all accessories fitted
7 CU on and done and tested dead and live
clear up get out get paid
oh and give Mike a Like
Are the numbers relating to days or order Vortigern? Is this by yourself or with a helper(s)?
As above, a number of you have mentioned help with the chases. I think it's time I gave it some thought.
Depending on the strength and condition of the existing mortar, you can sometimes get a good fix with clout nails (the thicker 3. something mm ones). Saves on drilling and plugging- not sure what wall dog is by the way
Wall dog....screws that don’t need plugs....quite pricey...but that sounds like a customer problem ?
Also goes without saying a decent twin disk wall chases and strong hoover attached are an absolute must..
I remember back in the 1990s doing my apprenticeship having to stitch drill chases then knock out the middle with a hammer and old beat up wood chisel...
Or these driven into the mortar joints: https://www.ebay.co.uk/itm/233191870707 They only need to hold until the first coat of plaster goes on.
Why put T&E in a conduit?
conduit allows for future rewiring / later alterations / additional wiring to be pulled in.
if you simply plaster in the cables the next bloke has absolutely no chance pulling in a new cable...
Don't understand your post Dusty, the hooks I put the link up for are to hold conduit in the chase?
The post above mentioned T&E and I was asking why you would put T&E in Conduit rather than single core.
How have you found those walldogs generally @Baddegg ? I find them useful for fixing direct to plasterboard, and they're supposed to be good direct to thermolite block. But I haven't found them to be much use in anything harder.
Love em mate, drill a smaller hole than stated and use an impact you’ll get a good fixing into brick work for back boxes, and agian once the bonding goes in and round the box it’s going nowhere
This French guide on max amount of cables in Conduit may be of help, but may not be within the UK regs:
HappyHippyDad
Supporter
Gloucestershire
Any advice on rewires?
HappyHippyDad,
brianmoooore,
