Don't understand your post Dusty, the hooks I put the link up for are to hold conduit in the chase?
The post above mentioned T&E and I was asking why you would put T&E in Conduit rather than single core.
Because the rest of the install is below The boards and clipped direct T&E you’d end up with junction boxes at every drop to a point. Very rare to have a Domestic completely run in conduit .
Conduit clips mean the oval stands out a bit far @happyhippydad, not much and anything that do t need to chased us a bonus, as per @Leesparkykent i just drill in behind at an angle plug it and then pinch the oval with a screw keeps it tight till the biding goes over ?
I am intending to try it with wall dog and no plugs just to speed things up a bit more ?
Do you use 20mm or 25mm oval conduit for 2 x 2.5mm twin &E baddegg?
I use 20mm oval HIppyDad ,just need to make sure the cables arent twisted and get pulled in evenly. I use the tower c clips to hold it in position, occasionally I when I run out Of clips I screw a couple of screws either side to pinch it into position. A squirt of werth Vaseline spray and a couple of turns of white tape around the end stops the tube from splitting. Get yourself a Rack a tier cable stand ,helps enormously when pulling in on your own.
  • Informative
Reactions: HappyHippyDad
Oh and add £1500 on to the price if the punter doesnt want to vacate during the work....occupied rewires are a massive pain in the ---
+1 for a spooler for pulling cables on your own... I try to pull multiple cables if I can... so having space on the spooler for more than 1 reel is a bonus.
I use the cheap Erbauer chaser which gives a perfect width chase for 25mm oval conduit from Toolstation.... just needs a little tap with a block of wood to snug it into the back of the chase... no need for fixings before plastering.
Reactions: loz2754 and Baddegg
Think I'd rather starve then do occupied rewires.
Always worth checking with mortar, cinder and concrete block as quite often you can get a reasonable fixing by going straight in with a standard screw and impact driver, just don't over tighten.
Useful for holding oval until filled, positioning trunking, not so much for mounting a DB.
Reactions: Baddegg
Same here... or listen to the entire back catalogue of Des O'Connor !
After this week with trying to move their rubbish about and stopping the dog escaping so would I.
Reactions: Vortigern
Only in the UK no one else uses T&E, very rare outside the UK to have domestic "not" run in conduit, mostly flexible plastic though.
I often use a cable stand when pulling wires, but because of the use of single's I need a big stand to take five cable reels at times and that is b****y heavy and also cumbersome in place's. Below image is the one I have, but not fully loaded.
Reactions: loz2754
ROI?
ROI = Return on Investment? Hmmm
And if you meant Republic of Ireland their regs changed in 2013, and the last chance to use the old stuff was a couple of years later.
The new regs issue in question was IS 201-4:2013.
Also the CPC is insulated and the same cross-section as the L and N, not reduced like the UK.
But I suppose it could still be classed as T&E but nothing like the UK version and has to be in Conduit.
I find it peculiar that so many chase and box before wiring? You cant alaways get the cable down where you want it might be a joist or an enexpected obstruction above.
@happyhippydad isnt there someone in your local community like a semi retired person that could just give you a day help here and there when needed? These jobs arent designed for one man teams, get it done pay your help and spend your evenings/weeknds with yoir family.
Im sure your apprehensive about getting help in but i have all sorts of people helping me from my local community and its great.
I always try to smash in all the cables before doing and chasing and boxing, I find the Bosch spade bits with threaded tip best for drilling joists quickly, and use wall dogs in plasterboard, woodscrews straight in blocks, red plugs and inch screws for everything else, I dont cap or oval, I make sure my chaser is set deep enough that no plasterer should be dipping his tip in and touching my cables, and just clip them neat. Dont do lived in rewires. Use good white wiring accessories like click or hamilton so you dont have to fold or twist ends like on hager with square terminals, wagos for neutrals in switches. Jcc gu10 downlights again pushfit terminals. And rcbo boards.
All little things saving time really do add up.
I don’t think I have ever done a full complete rewire on my own , except when it was an empty property and I had several weeks to complete the job.
Normally you would rope at least some help in to get the job completed in 4-5 days. Mash out the chasing and boxes on day 1 , so you can crack on with wiring days 2 and 3. Second fix day 4.
testing day 5. Job done...
Yea, you defo want a pair of hands for some of it, feeding in cables, r just reducing the burden of a house load of chasing in
No to mention , I’m only 42 and my knees , wrists and back are already giving my trouble...after an hour bent over doing feeding cables it takes me 5 minutes to get back up.
I don’t want to be a cripple by the time I reach 50.
there must be loads of youngsters out there looking for work experience, who would be ideal for bashing boxes & pulling cables etc
Most of the rewires I done have been occupied, there is an art to it unfortunately most electricians wont touch them these days.
Romex in the USA/Canada?
Plenty of retired folks out there who are fit and willing-I do such stuff sometimes. You will find that retired folks don't expect hefty pay-packets, will turn up on time, won't spend time on their mobile phones nor insist on having a site radio at full blast all day long. Maybe less keen to work a 10 hour shift, but happy to turn up for a few hours just when you need a hand. You might be surprised how many older folks out there have a bit of experience too. If you have a local branch of The Men's Shed charity, ask them if they have any suitable members. My branch has electricians, decorators, wetpants, CCTV and alarm experts, engineers and metalworkers, woodworkers and plasterers and many other skills. The Shed often has tools and machinery which may be of help if you need some welding or repairs, or just need your chisels sharpened. Tons of experience for not much money.
I did a lot of them on my own, OMG rooms full of furniture , move all in the middle of the room pull up carpets, then cut through 100 layers of lino, lifted minimal floor boards fish wires with my unwound metal coat hanger taped to oval conduit (before all the fancy mech aids you get now lol), repeat same in other rooms, hard bloody work.
Just updating this thread..
I've purchased the metabo wall chaser with triple blade and used it on a few jobs now.
I LOVE IT!
It takes out the entire chase, without any problem. One member mentioned that he was unsure about buying the triple blade as it may not cut through hard surfaces. It has gone through every surface I have tried it on so far, including red brick. Obviously the depth would make a difference, but I have it set to around 20 (I think), maybe 25mm) which is fine for capping and oval conduit.
The width that the triple blade cuts is perfect for 25mm oval conduit. It fit snuggly in with perhaps 2 mm left to drill a 5mm hole and screw in some concrete screws, no need for wall plugs. I use the pan head concrete screws and the conduit is completely firm.
I cant find the wall dogs @Baddegg, screwfix have sold out. I'm using these from screwfix Easydrive Countersunk Concrete Screws 7.5 x 50mm 100 Pack - https://www.screwfix.com/p/easydrive-countersunk-concrete-screws-7-5-x-50mm-100-pack/1066h
but they've sold out too! It's great not putting in a wall plug.
All you need to do now as a sideline is hire yourself out with it and get your money back.
Mind you I have no idea how much replacement blades are. :)
Reactions: loz2754
Making me want to upgrade my MFE30 to the 40 now!
I should add, I've only been using it for a month, so I've no idea of the longevity of the triple blade. Still worth a try though.
try a double glazing wholesalers for those screws @happyhippydad, window fitters use em every where....
Screwfix stock has gone to ---- lately, toolstation had wall digs though when I last got them, luckily my local stores are directly next to each other
Aren't all Toolstations and Screwfix next to each other?
Reactions: pc1966
They are in Havant, but I can’t speak for the rest of Portsmouth, the south coast, or indeed, the rest of the UK ??
They are in Maidstone and Sittingbourne, both in Kent, I think it's a bit like Aldi and Lidl once one arrives the others follow on, Oh also like bus's use to be when I travelled by them, can't remember the last time though.
Is that the Island of England or the Freezer food outlet.
Not on the island @JBW175 bloody miles apart....
That’a absolutely disgraceful planning mate, just to rub in, we’ve got Wall Dogs in stock....?
although I still miss going out on Albert & Palmy road, so you win that one. ?
Reactions: Baddegg
I’m pretty sure that he’s on about the isle of Portsea, and not to be confused with those 6 fingered webbed feet people from the IOW.
EDIT, no offence meant for any 6 fingered banjo players from the Isle of Wight that dabble in electrics.
HappyHippyDad
Supporter
Gloucestershire
Any advice on rewires?
HappyHippyDad,
brianmoooore,
